Needing a YDS cable in the DFW area @HELP
Truck4dog
Does anyone happen to have a YDS cable setup in the DFW area? I blew one of my engines and I'm in the process of replacing it and would like to pull hours for future reference. Also in need of a flywheel puller.
Thanks,
Jonas
just responded to your other post also,
tell us more about your engine, how did it blow? are you rebuilding or buy a replacement?
I ran it out of oil and threw a rod through the block. Got a new SBT engine to drop in. I'll probably weld the block and rebuild it for when the port engine leaves me. I have heard all of the bad about SBT, but after talking to them and with the warranty I took the chance.
sending you a pm,
I found both of them. I'm fortunate and have a friend with access to a forklift so the lifting will be a little easier. Great info! reading through, it looks like the only special tool will be the flywheel puller, unless I missed something.
while you have the engine out or while the hatch is off it might be a good time to pull your ECU boxes off and check them for signs of water intrusion and put them back on with a layer of silicone or tape of the seam,
Thanks for everything Scott!
