Big Shasta
- Panama City Beach, FL
- Boatless
- NA
- Other
- NA
The lifted slip we keep out boat on has AWESOME water pressure. I have a splitter and run both engines at the same time, never an overheat. BUT, the Crappy cheap salt-away dispensers don't handle the pressure very well...they would last about 3 months before they would break one way or another. Well, never again!
With some research and a topic I found on The Hull Truth, I bought this bad boy. Made for pressure washers, works awesome. I got the horizontal reservoir but the vertical one would probably work fine too. Just have to lay at an angle.
Reviews aren't great and it does drip from around the housing but no big deal. If it lasts one year, It's a win. MUCH easier to open and close than the plastic threads on the salt away and since I'm doing 2 engines at once, it holds plenty of solution. (Sometimes dawn detergent sometimes salt away.)
Available at your neighborhood home depot 20.00 or on amazon.com.
http://www.homedepot.com/p/Green-Ea...ector-for-Pressure-Washers-AP31024B/100665184
Not sure if the ratio is 100% the same but it seemed to turn clear in the res about the same amount of time the salt away dispenser did.
