Welcome to Jetboaters.net!
Did they run it on the hose at the dealer? If not then I wouldn't think so. Pull the battery and put it on a maintainer. If you are storing it outside, I would put a couple of containers of damp rid in it, in case moisture seeps in. If it is outside I would also make sure the tongue is up a bit to let water drain out the back. Also open your keel plug and leave it open as well as your clean out port make sure you unlock it at the very least set it loosely in tube or put it on the swim platform under the cover. If snow can get on it, make sure cover is tight and slopes so snow and water can run off.
