New 2004 SX230 Owner from Lake Barkley, Tennessee Area
jabroni1m
I just purchased a 2004 SX230 yesterday in Georgia. I feel I got a good deal at 14k. Boats upholstery is in good 7.5/10 condition. Outer hull is in 8/10 with a few scrapes and scratches from beaching. Engine compartment looks good. Both motors sounded good and revved up fairly high. I did notice the starboard motor 50 or so RPM lower than the port. I had to have the throttle slightly farther up to keep them in sync. Kind of annoying but figured it might be the throttle cable adjustment or impeller/wear ring issue. Boat didn't take on a single drop of water in 30 minutes ride. I attempted real quickly to get the plugs that let you unblock the impellers out and did not have luck. Not sure if they are stuck or my technique is bad. Any advice. I am going to search the forum after I post this. Looking for advice on what to do first. I figured I would do an oil change and new Iridium Spark Plugs first. I typically use Mobil 1 High Mileage Synthetic on all my vehicles and NGK spark plugs. Anyone have recommendations for this motor? I am in the Knoxville area until Friday and then will be towing it to it's home in Dover, TN. If there is anyone close by with the Yamaha Marine Diagnostic setup in either of these 2 areas, wanna come check for me? I am sure I will be posting more after searchign the forums for specifics. Thanks for all the information I have read so far and the many hours of reading in the future.
Cheers!
Michael
