bandit79
Howdy from Texas!
I will post in the Welcome section later, but I need to get a direction here.. I've done a lot of searching and reading here. Lots of great info.
I bought a 2006 AR21o last month and have had the boat out 3 times so far. The first time, when launching out of the hole (trying to pull skier/wakeboarder) both engines were hitting the rev limiters, and after some research on here I figured I had cavitation problems. It would take 15 seconds or longer to plane, if at all. Crawled under the boat, checked the grate seals and impellers. Seals seemed fine but starboard side impeller was beat up (see pics) I ordered and replaced the impeller and patched a hole, as whatever the previous owner hit, it poked a hole right next to the drive shaft hole.
On the second trip...The starboard side was working as it should, but the port side was still cavitating on launches. Again, inspecting the grate and impeller, I only found a small forward bend on the impeller but it was at the backside of one of the blades, or not a leading edge. I was thinking maybe the clearance between the edge of the blade and the wear ring was too big and causing problems. So I ordered and replaced port side impeller. Once replaced, took it out for the third time, and it is still having issues on the port engine. Again, trying to launch when pulling a wakeboard, it cavitates. It will also cavitate anytime you try to launch quickly.
A side note here: I did overfill the engines with oil on the first trip. Before the second trip, I removed excess oil and I did have some oil on the starboard air filter. I haven't tried it without the filters yet.
I have removed the port side pump again to have another look. The red arrow is pointing at the offset between the transom plate and shoe?? Of course, it is the opposite on the other side. I searched and I see some guys have smoothed that part out. Also, there is a lack of silicone there as well.
So, would that be enough to cause the cavitation? My only other thought at the moment is that maybe overfilling the oil, somehow has messed up the spark plugs on the port engine?
Your thoughts are appreciated!
--David
--David
