JodyHarrison
- Warrior, AL.
After checking the rear kill switches and determining that isn’t the problem, I took the fuel lines off of both motors to see if there was any difference from the starboard that will not crank and the port which does crank. I also hooked up the YDS software.
I started with the starboard side Which will not crank. Removed the fuel line going into the motor and there was no fuel at all in the line. I used YDS to activate the fuel pump and I heard a click but nothing else. Nothing running and no fuel coming out of the line. I activated the bypass motor and could heard it run. Also activated all of the injectors and could hear them run.
I went to the port side which Is running fine and repeated the process. As soon as I started loosening the clamp fuel started running out. Activated the pump and got a good steam of fuel coming out of the line.
So it looks to me the Starboard motor is not getting fuel. Any ideas?
