VONCE
- Dayton, OH
I finally checked my codes to see why my check engine lights were on. The codes on both engines were for the No Wake Mode switch. I recently replaced all of the switches in the boat. I never really use one engine more than another, and every time I turn on no wake mode I simultaneously turn it on both engines. Because of this, I just combined both into one switch. I got a momentary double pole (two separate circuits) switch. I tested the old switch with my multimeter, and it simply connects the two wires that go into the switch. So I thought my new switch would work fine since it operates the same way. The fancy Yamaha diagnostic software has a live engine monitor, and the no wake switch was something you can monitor live. The new switch in its current setup seems to be working fine. It's off until the switch is pressed. Once the switch is pressed, the monitor shows it is on. I deleted the code. Well, I still have my check engine light when I start the engine. The code comes right back. Any ideas?
