NOCO 5x2 Charger and Voltage Sensing Relay
BBoater
252XE
I bought a NOCO 5x2 Charger and was planning to leave it wired up to my batteries. When I tried charging the batteries it tripped the voltage sensing relay. Forgot to consider that. I understand the VSR connects the batteries together when the red light is on.
Is it OK to have the 5x2 connected to each battery. It should be feeding 5 amps in on each battery, safe when they are connected together?. Or should i just use a single charger on the Starter battery and let the VSR flip over to house similar to when the boat is running?
Works flawless when the above hack is done.....all summer long and zero issues.
