O2 Sensors, 2014 Scarab 195 HOI
ChristopherDHall
HO Impulse
Searched and searched and finally found the ones! 13444, Bosch
ChristopherDHall
HO Impulse
You’ll get a code on your dash when they do.
PO13F / PO13A
PogoFX
Navarre, FL
HO Impulse
Thanks!
Jwood1508
Jacksonville
HO Impulse
I know it’s an old thread but how did the 13444 O2 sensor work out? When I pulled my O2 sensor or cross referenced to a 18127 but the 13444 looks like a perfect fit.
slaubman
Toronto, Ontario
215 ID
HI, bumping this thread again as I'm also interested in whether the 13444 sensor worked? I have a fault code for my pre-cat port side sensor but am having real difficulty locating either a Bosch 18127 sensor or the OEM versions to replace it.
Dean P
Florida
Chaparral
VRX
I have used other brands and pt no from various companies and as long as the sensing unit and the connector are identical go for it; just make sure the wires are long enough. Worked for me.
Scarabpaul
Bradford, Ontario, Canada
out of curiosity, since there are two O2 sensors per motor, are both the same model numbers?
