Odd speedometer problem - continuously bouncing from minimum to maximum
bcage
On my last trip out, a new problem surfaced on my 2014 AR240. The speedometer began bouncing from full counter clockwise to full clockwise - non stop. This is the typical behavior for the speedometer (as well as the tachometers) when the engine is being started except that it usually does a single cycle and then settles into the appropriate reading (current mph or rpms for the tachs). Right now, the speedometer goes through the cycle continuously; never stops; never shows the actual speed being traveled.
Any insight into this? I found one other posting for the same issue from a couple of years ago, but there were only a couple of posts and no answer. My first inclination is that it might be a short, but I don't know.
Hopefully someone can point me in the right direction to chase this down. Thanks ahead of time.
SOLVED: Diagnosing the problem, I noted that the GPS puck was not receiving 12V. Disconnected the wire from the puck at the connector under the dash. Noticed that there was corrosion in the plug. Disassembled the connector and found a wire had corroded through. Cleaned up the wiring, resoldered the broken wire and the problem was fixed.
