Oil filter
Jbaref2
What's a part number for the oil filter for a 07 AR230 with Mr1 engine and what's the suggested oil gonna see if I can get filter from a local parts house
Yes plugs have been changed also
Fyi i believe it actually calls for 10w40 bit most everyone is fine with 10w30 unless you plan on surfing with 3 people behind you and 3000 lbs ballast on a 110 degree day.
Remember dino oil breaks down to the lesser number (10) and synthetic breaks down to the higher number.
@Speedling if I remember right the MR1 is 10w30 and the 1.8 is 10w40.
Just going off stickers and no means to start a debate.
You could totally be right there. I know that a lot of the motorcycles use like 15w50 and the mr1 is motorcycle derived. Perhaps that is what i was thinking of.
