Oil treatment
Van T
Chesapeake va
Has anyone tried Hot Shots fr3 ? Dyno proven horsepower gains increase of lubrication properties of 43% penetrating friction reducer and a normal 5% increase in fuel economy . Most diesel people swear by HotShots products.
No one at all hello McFly everyone here trying to get more power out of their Motors by doing labor intensive stuff this seems like something could be easy and cheap . Friction and Heat the number one reason to lose horsepower.
No I wanted to try some ordered some for my trucks
I've heard of several products claiming performance like this lately. Assuming it’s not snake oil I think it’s a great idea.
It would be nice to see some real-life test results.
I have read good things about Gas-Shock, but it is not available locally as far as I can tell.
Most of these things are a waste of money if you are using a top tier fuel with detergents.
The problem with oil additives is that adding things to the oil disturbs the carefully crafted additive package the ol manufacturers have included.
The new oils are the best ever and screwing with them is probably a bad idea.
The only major oil company that sells additives I know of is LubroMolly (a German company) that sells an additive that I would assume is compatible with their additive package.
Quaker State makes Slick 50 and oddly they do not suggest adding additives to their own motor oil.
Tests have shown that Slick 50 did make some improvement in friction losses and fuel economy, but had higher pressure drop across the filter and had higher Iron on oil samples.
I have used the Lubro-molly (Molybdenum disulfide, known as Moly or MoS2, has long been used as a friction reduction additive in personal and commercial vehicle engines and drivetrains.) and it may add some protection, but it is hard to prove.
If you operate a fleet of trucks treat half of them and not the other half and let us know.
Many new oils have additive packages that clean off their old coatings and replace it with their new and with these oils the oil change interval should reflect this as the latter part of the cycle builds up the new protective layer after removing the old. and you may be doing the oi a disservice by changing it too soon
You'd likely be better off making sure your hull stays clean and waxed if you're wanting best efficiency. Also if you remove the tons of warning stickers they are worth .1 hp each easily :D
Dyno runs two of the same trucks five base line runs each , the one with the additive gained 8 hp not bad if true. If you know heat soak is number one hp killer ,If you reduce fiction, less heat equals more hp you don't loose .if I can get longer life out of my engine that's all I need . Some people sent oil in to get analyzed before and after using product for a while and had less trace metal amounts in oil . Some were regular trucks some were semi trucks with high miles . Like I said don't know just read this on different web forums.
The heat from friction isn't even 1/100th of a percent compared to the explosions. Egt on these could be 1400f easy.
I could do 5 baseline pulls right after strapping the vehicle after a long hot drive and get my "stock" hp. Spend 30min to an hour while fans are going on an open hood while sprinkling fairy dust in the intake, then do 5 more pulls to prove the fairy dust makes 8-15hp. Unless they publish data logs with timing map/maf, ect and iat I'll call bs every time for low gain claims. I wrote this a while back when dyno testing an intake on my jeep with 18 pulls and statistical analysis.
http://www.tricktuners.com/forums/showthread.php?t=226
I made 30hp by sticking a bag of ice on a blower for 15 minutes because the customer wanted 600+.
After years posting on car forums, this is the only forum I regularly post on. It's got a nice group of people, and a smooth phone interface. Most of all its not full of idiots posting crap.
Thank you!
Hopefully, this will do. LOL.
Some people missing the point if I can get get longer life out of my motor it's worth a try and I also don't like people on forums with all their crap, but I have personally seen their products work on diesel trucks make injectors work again at otherwise would have had to been rebuilt or replaced I'm not saying the stuff is going to work . But all their other products do work. Sorry I don't have my PhD in knowing everything like half the people on here because there's definitely some smart people on this forum. I know you can't get so much out of these boats there a boat with a little jet ski motor in them . But they're still badass Machines
You don't need to have a Ph.D. to know you're not going to get 8 hp from an oil additive :D
If you want to try it just buy it. Personally I think it's a waste of money as I'm a skeptic of any product with the words "Secret formula". It's probably made from the ores of unobtainium deep in the forests of dreams.
Here is a link to an expensive German additive and the announcer has a British accent so you HAVE to believe!
By the way The company makes premium oils and additives and sells both.
Most oil companies do not sell under the same name and they do, if that means anything.
https://www.youtube.com/watch?time_continue=65&v=xXvZByUPpEo
Disclaimer
Do not remove this disclaimer under penalty of law.
For optimum performance and safety, please read these instructions carefully.
Void where prohibited. No representation or warranty, express or implied, with respect to the completeness, accuracy, fitness for a particular purpose, or utility of these materials or any information or opinion contained herein. Actual mileage may vary. Prices slightly higher west of the Mississippi. All models over 18 years of age. No animals were harmed during the production of this product. Any resemblance to actual people, living or dead, or events, past, present or future, is purely coincidental. This product not to be construed as an endorsement of any product or company, nor as the adoption or promulgation of any guidelines, standards or recommendations. Some names have been changed to protect the innocent. This product is meant for educational purposes only. Some assembly required. Batteries not included. Package sold by weight, not volume. Contents may settle during shipment. No user-serviceable parts inside. Use only as directed.
Do not eat. Not a toy.
Postage will be paid by addressee. If condition persists, consult your physician. Subject to change without notice. Times approximate. One size fits all. Colors may, in time, fade. For office use only. Edited for television. List was current at time of printing. At participating locations only. Keep away from fire or flame. Avoid contact with skin. Sanitised for your protection. Employees and their families are not eligible. Beware of the dog. Limited time offer. No purchase necessary. Not recommended for children under 12. Prerecorded for this time zone. Some of the trademarks mentioned in this product appear for identification purposes only. Freshest if eaten before date on carton. Subject to change without notice. Please allow 4 to 6 weeks for delivery. Not responsible for direct, indirect, incidental or consequential damages resulting from any defect, error or failure to perform. Slippery when wet. Substantial penalty for early withdrawal. For recreational use only. No Canadian coins. List each check separately by bank number. This is not an offer to sell securities.
Read at your own risk. Ask your doctor or pharmacist. Parental guidance advised. Always read the label. Do not use while operating a motor vehicle or heavy equipment. Do not stamp. Breaking seal constitutes acceptance of agreement. Contains non-milk fat. Date as postmark. Lost ticket pays maximum rate. Use only in well-ventilated area. Price does not include taxes. Not for resale. Hand wash only. Keep away from sunlight. For a limited time only. No preservatives or additives. Keep away from pets and small children. Safety goggles required during use. If rash, irritation, redness, or swelling develops, discontinue use. Do not fold, spindle or mutilate. Please remain seated until the web page has come to a complete stop. Refrigerate after opening. Flammable. Must be 18 years or older. Seat backs and tray tables must be in the upright position. Repeat as necessary. Do not look directly into light. Avoid extreme temperatures and store in a cool dry place. No salt, MSG, artificial colouring or flavoring added. Reproduction strictly prohibited. Pregnant women, the elderly, and children should avoid prolonged exposure to this product. If ingested, do not induce vomiting. May contain nuts. Objects in mirror may be closer than they appear. Do not use if safety seal is broken.
Apply only to affected area. Do not use this product if you have high blood pressure, heart disease, diabetes, thyroid disease, asthma, glaucoma, or difficulty in urination. May be too intense for some viewers. In case of accidental ingestion, seek professional assistance or contact a poison control center immediately. Many suitcases look alike. Post office will not deliver without postage. Not the Beatles. Products are not authorized for use as critical components in life support devices or systems. Driver does not carry cash. Do not puncture or incinerate. Do not play your headset at high volume. Discontinue use of this product if any of the following occurs: itching, aching, vertigo, dizziness, ringing in your ears, vomiting, giddiness, aural or visual hallucinations, tingling in extremities, loss of balance or coordination, slurred speech, temporary blindness, drowsiness, insomnia, profuse sweating, shivering, or heart palpitations. Video+ and Video- are at ECL voltage levels, HSYNC and VSYNC are at TTL voltage levels. It is a violation of federal law to use this product in a manner inconsistent with its labeling. Intentional misuse by deliberately concentrating and inhaling the contents can be harmful or fatal. This product has been shown to cause cancer in laboratory rats. Do not use the AC adaptor provided with this player for other products.
DO NOT DELETE THIS LINE -- make depend depends on it.
Warranty does not cover normal wear and tear, misuse, accident, lightning, flood, hail storm, tornado, tsunami, volcanic eruption, avalanche, earthquake or tremor, hurricane, solar activity, meteorite strike, nearby supernova and other Acts of God, neglect, damage from improper or unauthorised use, incorrect line voltage, unauthorised use, unauthorised repair, improper installation, typographical errors, broken antenna or marred cabinet, missing or altered serial numbers, electromagnetic radiation from nuclear blasts, microwave ovens or mobile phones, sonic boom vibrations, ionising radiation, customer adjustments that are not covered in this list, and incidents owing to an airplane crash, ship sinking or taking on water, motor vehicle crashing, dropping the item, falling rocks, leaky roof, broken glass, disk failure, accidental file deletions, mud slides, forest fire, riots or other civil unrest, acts of terrorism or war, whether declared or not, explosive devices or projectiles (which can include, but may not be limited to, arrows, crossbow bolts, air gun pellets, bullets, shot, cannon balls, BBs, shrapnel, lasers, napalm, torpedoes, ICBMs, or emissions of electromagnetic radiation such as radio waves, microwaves, infra-red radiation, visible light, UV, X-rays, alpha, beta and gamma rays, neutrons, neutrinos, positrons, N-rays, knives, stones, bricks, spit-wads, spears, javelins etc.).
Other restrictions may apply. Breach of these conditions is likely to cause unquantifiable loss that may not be capable of remedy by the payment of damages.
This supersedes all previous disclaimers
Entire contents (c) 1999 by Our Group, Inc. This disclaimer is protected by copyright and its use, copying, distribution and decompilation is restricted. All rights reserved. No part of this disclaimer or any attachments may be copied or reproduced, stored in a retrieval system, or transmitted, in any form, or by any means, optical, electronic, mechanical, photocopying, recording, telepathic, or otherwise, without the express witnessed and notarised prior written consent of the all holders of the relevant copyrights.
The information contained herein has been obtained from sources believed to be reliable. However, no warranty as to the accuracy, completeness or adequacy of such information is implied. No liability is accepted for errors, omissions or inadequacies in the information contained herein or for interpretations thereof. The reader assumes sole responsibility for the selection of these materials to achieve its intended results. The opinions expressed herein are subject to change without notice.
The information in this document and any attached files is strictly private and confidential and may also be privileged. It is intended solely for and should be read only by the individual(s) or organisation(s) to whom or which it is addressed. If you are not the intended recipient, or a person responsible for delivering it to the intended recipient, notify the sender by return, delete the message, and destroy all copies of the email and associated files in your possession; you are not authorised to and must not disclose, copy, distribute, or retain this message or any part of it. It may contain information that is confidential and/or covered by legal professional or other privilege (or other rules or laws with similar effect in jurisdictions outside England and Wales).
We have an anti-virus system installed on all our PCs and therefore any files leaving us via email will have been checked for known viruses, but are not guaranteed to be virus free. We accept no responsibility once an email transmission and any attachments have left us.
No part of this message is intended to form any part of any contract. The views expressed in this message are not necessarily the views of my employer, and the company, its directors, officers or employees make no representation or accept any liability for its accuracy or completeness, unless expressly stated to the contrary. This message is not intended to be relied upon without subsequent written confirmation of its contents. This company therefore shall not accept any liability of any kind which may arise from any person acting upon the contents of this message without having had written confirmation.
This document originates from the Internet, and therefore may not be from the alleged source. If you have any doubts about the origin or content of this document please contact our Support Desk.
Moral:
This mail could have come from absolutely anybody masquerading as the sender, could have been read quite legally by the State under the RIP legislation, by the security services of any other state through which the data passes, by the sender's or receiver's employer on the pretext of protection of business interests, and read or altered by anybody working at any of the infrastructure services involved in its transmission. Given that internet routing is complex and adaptive, you don't even know who most of these parties are. Why not use encryption next time?
If you get 8hp and 10% longer engine life per bottle, you should add ten bottles! 80hp and double engine life! That's proven results! If you buy from the vendor with the highest price you get the fresh stuff too. Remember that additives "stack" so throw in a couple slick 50s and some seafoam. You'll be pushing 1000hp before you know it.
What if I put the product stickers on the side of boat too, how much more horsepower will I get then? And a black ice Christmas tree air freshener hanging from my mirror
As I mentioned earlier you'll get approximately .1 hp each for stickers, so go crazy for maximum output! If you vinyl wrap it with a sponsor then I think you'll need to add a wing to keep that boat on the water. It may not even be legal to have it on small lakes due to all the power it would have. You'll probably need to upgrade to a 160mm jet pump just to harness the thrust or you'll likely blow out the back of your boat!!
My t top is kind of like a wing shakes like hell sometimes I think it's going to rip off the deck think I might build some bracing underneath I think if I add any more weight I'll be able to go full Throttle and it'll be perfect surf speed
You MUST be careful, not only do you get all of that extra power, but you have to do something to keep from blowing out the gas tank, maybe fill the ballast tanks until they over flow and then fill the pull behind tubes too,.
So much to take into account.
Too much and you might have to figure out what to do with the extra engine generated from the anti-wear additives part
Remember.. when placing the stickers make sure the letters are leaning backwards if u want speed... lean the letters forward if u want you boat to handle better! Its dyno proven!!
