Ba6257
- Columbus, GA
- SS
Hello,
I've recently purchased a 2009 212SS. My family has a small cabin on the lake with a boat house. The lift is currently configured for a pontoon boat and I need to convert over to fit my boat. I've talked with the company that made the lift, Doozie, and have ordered some new cables (the ones on there are 20+ years old) and some adjustable bunk mounting brackets.
My questions have to do with the bunk boards:
What boards should I use? 2x8 or 2x10?
Should I use a single board on each side or should I use 2 boards bolted together for more strength to keep them from bowing out in the middle?
Board length?
What is the correct spacing between boards to fit the bottom of the boat?
Anything else I'm not thinking of?
Here is a picture of how it is currently configured. The mounting brackets are currently welded on and I'll have to cut them off and grind them flush. Also there are 2 foot long sections of railroad track bolted to the tops of the cradle to help sink it. Thinking I'm going to have to move them or do away with the completely, not sure if they are needed.
Also attached is a pic of the boat sitting on the trailer. Not sure if I need to mirror the distance of the inside or outside bunks as they are?
Thanks for your help.
Board length?
