ncnmra
- Ontario, Canada
- X
I had one of my servos seize this weekend. Basically at that point, PP won't work, and you can tell because you can't spin it by hand.
I've had it just 1 year. PP customer service was great, and they agreed to send me a new servo, but I also had to buy a new cable because I broke the knob trying to un-seize the servo on the water.
If this happens to you, don't bother trying to un-seize on the water, but rather take the servo motor out and disassemble it. I have done this with my broken servo, so hopefully I will have it as a spare.
There is a discussion about this on the Mastercraft forum:
https://www.mastercraft.com/teamtalk/showthread.php?t=69201
I was shocked that the servo motor is not sealed. In my case, it appears that there may have been some mild corrosion that caused the internal parts to grind together forming a black dust inside which caused it to finally seize completely.
I ended up painstakingly cleaning out the rotor and windings and using something called "PL-100" to lubricate it. It is advertised as being a penetrant and lubricant, as well as having excellent dielectric properties. I will see if my efforts paid off in a few days when I can get out to the boat.
