Port engine won't start
waternutt
Panama City, FL
Chaparral
VR
[USERGROUP=9]@HELP[/USERGROUP] Also posted in the Chaparral forum...hoping to take the boat out today but my port engine will crank but not fire and I am getting the 4 codes (P0201, P0202, P0203, P1030).
I accidentally left the battery switch on after our last trip weeks ago. So it is safe to say the batteries were probably drained but I did not try to start it. However, I did just replace the batteries earlier this summer and the boat has been sitting in my driveway on a charger since Thursday.
Any thoughts? I do not have a way too clear the codes without getting it into the service shop. Fuses and wiring all look good.
UPDATE: Pulled the fuel rail and I was getting zero spray from the injectors. Bad ECM?
I would double check that you have all of the wiring to the batteries hooked and in the correct positions. Have you tried disconnect ting the batteries for a few minutes and hooking them back up to see if it will reset?
Thanks for the tip. I tried it out but unfortunately the codes remain and the engine will not start. Off to the repair shop I guess to see if they can clear the codes and figure it out. Everything was running fine last time I had it out.
