- Royal, AR
- SX
I am in the process of changing impellers. I decided to pull the pump housing and gently fit them into it instead of possibly letting the scrape as I reassembled the pump to the boat .
@Rana noticed that the port impeller leading edges sit slightly beyond the outer of the pump housing. I compared to the starboard pump and found its impeller leading edges are around half an inch inside the pump housing.
I installed the factory starboard impeller in the port pump and found it sat fully inside the housing as it would on the starboard side. I also reinstalled the factory port impeller and found it sat with the leading edges proud of the pump housing. The issue (feature) must be related to the thread on the 6P600 impellers.
All of the impellers are Yamaha impellers with factory part numbers stamped into them.
Has anyone else noticed this? Is an explanation out there?
Here is a picture showing the difference. The port pump is on the right.
![IMG_2538.JPG](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/57/57898-7d1df356a83d2fac3ab521379fedbf97.jpg)
