swatski
- North Caldwell, NJ
DISCLAIMER: I have too much going on in my work and in my life.
So, naturally... I seek time-wasting distractions such as internet forums, 87 vs. 93 octane, and reading about superchargers. ( yes, those are the real reasons for starting this thread; and yes, it is better than therapy, lol)
I started experimenting with low (87, regular) vs high (93, premium) octane after reading about new-er Toyota engines being controlled by sensors - almost entirely.
The way I understand it, Toyota has decided to allow the software (algorithms) to take raw data, in real time, to calibrate and run the ECUs so there is no actual "tune", more like running within a "constant variable" depending on readings from sensors - pre-drivetrain, post drivetrain, and everything in the middle...
One of the things I read that made an impression on me was the DAP tuners claim that "These engines pull 8-12 degrees of timing due to knock retard on 87 oct, 6-10 deg on 89oct, 2-6 deg on 91oct, and 0-2deg on 93oct. That is on a completely stock truck with factory tune." Wow! (if that's true).
Which poses some interesting questions, and makes some specific predictions.
Will it run perfectly fine and reliably on 87? Yes.
Will it run better on higher octane? Probably.
I decided to look into this some more. Over a period of time I ran my 2017 5.7 V8 Toyota switching half-tanks of either 87 or 93 gas (running on empty in between to minimize mixing the two grades).
Consistently, my engine was noticeably quieter running 93, under no/various loads. Most notably, the engine did not down shift as much compared to 87 gas - most apparent at highway speeds, but similar when driving a local route - going over the same hills and keeping the same speed.
(I didn't notice any better/changed MPGs.)
I also ran another Toyota truck, wife's 2016 4Runner 4.0 V6, on 93 vs regular octane and again seen more power and engine not down shifting as much with 93 as compared to 87 gas - driving the same route, same hills and speed.
(Again, no increase in MPG)
I conclude that with these trucks 93 octane provides for more power (through more timing?) under a given load.
That additional timing and resulting power would undoubtedly come in handy towing our boat - for example around Arkansas hills on trips to Bull Shoals Lake!
But - if 93 octane really gives me more power - I would run it all the time.
Thoughts?
Thoughts?
