Aces_Over_Kings
- SeaDoo
- Other
Hi folks,
If it has a mouse and keyboard, I can build it, fix it, or program it. But if it has an engine... yikes. So here I come asking questions.
I could really use help with some step-by-step maintenance in the engine compartment:
Thanks in advance for any pointers!
- When washing/flushing the boat after a salt-water ride, I flush the engine with Salt-Away (and wash the whole boat with it), but I've seen people recommend doing the engine compartment also, either with Salt-Away or simply rinsing everything down with fresh water. Is there anything in the engine compartment that shouldn't get wet? The photo below isn't mine, but looks more or less the same. Is it really okay to rinse of the engine?
- If so, it seems like there should be another step. Hand dry everything? Air dry? Hit it with XPS Lube? T-9? Battery terminals with dielectric grease?
- What else do you guys do to keep corrosion at bay?
- What about the bilge pump, any maintenance or lubrication there? I thought about closing drain plugs and filling with salt-away mixture and running the bilge pump, but figured I'd check first.
