Quick tip avoid splicing wires for amp
AJack
Tampa 33621
Instead of splicing into the factory speaker wires when installing an amp, use the wire harness below. All you’ll have to do is cut off the black 16 pin plug, connect the ends of the wire to your amp, and plug into the Polk harness.
Note: completed on a 2018 SX240 with the Polk PA4A system.
Do you have a pic of the connection. I'm not sure how this inter connects. Im looking to do the same with an aftermarket amp.
