Raw Water Wash down
Augieol65
Downers Grove
Almost done thanks to everyone’s help with the raw water wash down for the dogs and the boat. Through hull placed on the rear and piped to the engine compartment where the pump is located. That is plumbed to a quick connect fitting I placed in the spot the light pole goes on the SX models. Looks good I believe. I have the pump on a switch even though it has a pressure switch. No need for it running or pulsing when I’m not using it.
Ok where did you get the wash down connector? Don’t make me go on the internet!
Looks great, I'm just finishing up my system as well.
Just curious how your Raw wash has been working out for you? Any way you could forward what pump and switch you used? Thanks in advance
