Removing driver seat to install sea dek
Vito Aiello
Does anyone have an idea how to remove the driver seat. I'm installing my sea dek. Thanks
Just turn the lever to slide the seat forward (or swivel, I can't remember) then just pull up. I use to pull the seat every time I'd wash the boat and clean under it. It's also useful when trying to dry the seat and making sure all the water is out of the seat.
Thanks, I'll give it a try
I have to turn mine 45 degrees outwards then pull up. Goes back the same way.
You may have to swivel a little and then also slide back back and forth too at the same time; that's what I had to do.
BE CAREFUL if you turn the removed seat upside down and move the seat slide or swivel. there is a spring in there that can come out and it's a *itch to get back in.
Just following up on this. If you remove the seat and adjust the seat lever the spring will more than likely all out. If you this happens to you see below.
The first image shows all the things you have to remove. Then slide the slider seat piece to the front and about half way off the slider base. This will expose the location of the spring. The second image shows what the spring looks like when installed properly.
