TimW451
- Sassafras River, Chesapeake Bay
- SX
I undertook a job to replace the fuel vent in the hopes it will correct my issue with the gas pump cutting off frequently when filling up. (The theory being that it can't vent fast enough. The old vent's screen is well blocked, at least 50%.) My issue now is that the newer/current vents are slightly larger than the old one (luckily the pipe part is the same, so no issues with hose size.) The old one fits in a 3/4" hole, but the new one needs a 7/8' hole. While I have a 7/8"hole saw, it is meant for new hole, i.e. an arbor to guide it, which won't work here. I guess a step drill bit is the right option, but I'll have to buy one, I don't have that size. I could also just dunk the old vent in CLR and reuse it. What would you do?
