lgparra
- Tampa, FL
- AR195
So after receiving my boat back from the dealer for the initial 10-hour service I was out on the water and I couldn't get the engine to rev above about 6200ish RPM's. My initial thought was I sucked something up. Did the cleanout port dummy checks but nothing was apparent. Dug a little further and found my throttle cable wasn't tight against the stop. Adjusted that quick but was only able to get up to about 6500ish RPM's. Dug a little further by checking the spark plugs, correct gaps, torqued properly, etc. And then I got to checking the oil level. Come to find out the dealer way over-filled the oil . The oil level was a considerable amount above the high mark. I ended up sucking out about 2/3 of a quart of oil and now the oil is pretty dead center between the high/low mark on the dipstick. Took the boat back out and was able to get up to 7500-7600 RPM at WOT. So I think the power loss part of it is solved. However, I am still getting some pretty bad cavitation when taking off (not slamming down on the throttle but just taking off to get up to speed from idle). While looking in the intake grate I found a pretty sizable chunk of sealant sticking out. So my question to you guys is should I perhaps remove the grate and carefully cut it off that excess sealant with a razor blade? I don't know if it's the cause of cavitation but I'd have to imagine it's disrupting the flow into the jet if only a little bit right? Thanks guys!
