Rocket launcher main pipe dimensions
LeonPhelps
Does anyone know the dimensions of the main pipe on the rocket launchers ? Im trying to figure out if I can mount a UHF antenna on there.
sorry i meant diameter
I mounted mine there. I believe it is actually 1.25" used the standard Shakespeare 4188-SL Rail Mount Ratchet Mount for 1" to 1.5" Rails
mount plus a small stainless steel washer as a shim to one side under the mount to compensate for the downhill lean of the t-top frame (you'll know once you put the antenna up)
Yep. Bracket above is what I have on my t-top as well fits great.
Any Pictures ?
