Round flush mount table leg base dimensions...
Kimadams
Does anyone happen to the dimensions for the base for the table leg? I bought a new one thinking it would work... too small. It is for a Yamaha Ar230 2009.
Mine uses what is called a “stowable” table leg and base from Springfield Marine. They have another type called the “locking” table leg which is different
Do you know the dimension of the pole or the hole of the base?
IIRC, the pole diameter is 2-3/8” and tapers down to 2-1/4” on each end.
