Englewoodcowboy
- Ceres, VA
- X
OK, new owner of a yamaha AR192. Out of the box the motor would only rev to 7000 rpms and do approx. 42 mph. When I took the bimini top down it would do 7200 rpms with a top speed of 44mph. As of today I have ran 1 full tank through it and been out for 2 days. I checked the throttle adjustment and there was approx. 1/8" gap at WOT. I have adjusted it today so there is maybe .015 gap at WOT to avoid excessive stretch or bottoming out the electronic throttle but will not be able to run it till this weekend. I am running my boat at approx. 1400 to 1700 feet ASL depending on which lake I am on. I am not looking for it to be spot on as I know there will be variations from one to the next due to MFG tolerances etc. I am not looking to get what is stated but what others have seen as real world experience. I have zero complaints with the motor at this time as I also know that re-pitching may need to be done to compensate for elevation etc. if I feel like the hole shot is lacking etc. I have pulled a tube with it so far and was happy with how it pulled the rider up. What I would like to know is:
1) What is the max RPM our engines are set to rev to.
2) At the stated elevation, what should I realistically expect for performance since I will not have an At Seal Level experience to compare to.
3) Are there any other items I should check and or adjust to make sure it is running at its best performance?
