gallobg
- MasterCraft
- Other
I successfully ran speaker wire up the tower yesterday in a 2019 AR195. I tried a new trick to get a lead rope through the tower and it worked really well so I thought I would share.
I used some neodymium magnets to drag the lead rope down the tower. First, I drilled the tower speaker holes using a step bit like others here. Be warned, those metal shavings fly EVERYWHERE. I put down a few towels to catch the shavings but it really didn’t make a difference.
For the lead rope, I used duct tape to secure one magnet to the end of the rope. Next I inserted the rope into the tower speaker hole and then I used a second magnet on the outside to capture it and slowly lead it along the tower tube. The factory towers are non-magnetic so this worked extremely well. I was able to easily run the lead line all the way to the bottom of the tower bracket in just a few minutes, at any time I need to stop the magnets held each other in place.
At the bottom, I fashioned a retrieval tool out of a long zip tie. I used duct tape again to secure another magnet to the end and used this to fish out the lead rope at the bottom end of the tower bracket. It took a little longer to catch the magnets together because it’s a blind operation, but it actually wasn’t that bad.
After that it was an ordeal running two 14awg wires up the tower due to their thickness (they barely fit together in the small gap where the tower attaches to the boat) but the lead rope did it’s job to pull the speaker wire through. In hindsight I probably used too light of a rope because I was concerned it would break considering how much friction the speaker wires had, but it held and I was able to get them through eventually.
Anyhow, the lead rope took only about 10 minutes to get down the tube so I would definitely suggest that to anyone doing this! Of course running the speaker wires back up took considerably longer due to the tight squeeze…
