WiskyDan
- Jackson, WI
- 242 Limited S E-Series
So, this came up in another thread that I was active in and we got to talking about tying up at sandbars - approaching and anchoring safely/securely.
I'm going to my first sandbar on Friday and I'm a bit nervous - don't want to be "that guy" - so any tips/tricks would be appreciated.
Here's what my sales guy who owns a Yamaha told me:
Here's some really good info from anmut:
Come in slow, do a 180, put the bow anchor out, go slowly into reverse to set the anchor. Then attach the bungee line for my Sandshark to one of the stern cleats and walk out until there is good tension on it, drop the bungee line, auger in my Sandshark so it's at least 50% buried, then attach the bungee line to the Sandshark. I bought a box anchor for the bow that should arrive today and the Sandshark was part of the accessory pack that I bought with the boat so I'm hoping it's solid. I don't want to be "that guy" at the sandbar.
I've considered that move in pulling up to the sandbar but decided against it. Our sandbars are 2-4' deep for a good length of distance until you hit the channel and it drops off. Because reversing needs more throttle than going forward, it causes a lot of thrust disturbance right into the sand below the intakes, and the buckets are down that sounds like a good way (to me) to jam something up in your impeller or buckets.
I pull in the fun way - get some speed coming in at 5' of depth, set throttle to first forward detente, then just watch the depth finder. At 3', cut the throttles, open the buckets all the way up (forward) to allow pass-through, and jump to the back of the boat. Jump in the water, grab the pull handle, and swing the boat around. Then I auger in two land anchors into the sand about 5' away from both stern cleats and use the airhead dock bungees to clip the boat to the land anchors. This allows the boat to float with waves but also keeps it planted between the two land anchors in all directions.
