Welcome to Jetboaters.net!
2018 Scarab 165 charged the battery. Started fine slowly cruising around and the engine cut out. Gauges all work but wont crank. 3/4 tank of gas. Any thoughts
Won't crank at all? Does it click? I'd start with your relays in the fuse box behind the battery. Otherwise, check connections and make sure they are clean and solid.
