Scarab 195 Open Fuse Panel
Jcombs
195 Open ID
Trying to see if anyone had a picture of the fuse panel located in the center console on the 2018 Scarab 195 Open ID with the 200HP Rotax. Having issues with the baitwell pump not working and wanting to check for power. The current labeling on the fuse box is not readable. Thanks in advance.
Yes. Doesn’t look like the accessory fuse is located there I guess. My model has a baitwell included and the pump worked momentarily and then quit working. Boat only has 14 hours on it but is no longer under warranty so I’m trying to pinpoint the problem.
Guess I’ll check for 12v at the pump and go from there.
There's a secondary fuse box by the engine I believe. Have you checked it? On the 165 it's by the battery. But not sure on your model.
There is. I checked the fuses there and they were all good. None were blown.
OK, yeah, carry on with your investigation. But with 14h, I presume you could also call your dealer if needed.
I’m going to but when I bought it, I became the second owner so not sure if they will help me out. Thank for the image though as I can’t even read the one on the box in the center console.
FYI, two sites to bookmark:
Scarab Owner's Manuals (where I got that picture):
BRP Operator's Guide:
Select JPS Rotax, two letter code that corresponds to the last two letters of your engine model number, then HP. Your engine model number can be found under TWO plastic covers on top of your engine. Take the obvious one off to access spark plugs and you'll see a second not obvious plastic cover. Pop that off too to find the label.
