Carlos Alfonso
- Scarab
- Impulse
Hi Everyone,
I am wondering if anyone has had any issues with the ignition switch of a Scarab 195 2014 or similar.
About a couple months ago, the switch started giving trouble. Although I had the throttle handle in neutral, and the safety clip in place, I had to move the handle back and forth and try several times until the engine turned on. Battery is fine.
Last week that little trick did not work any more and the engine will not start at all. A friend checked the sensor but found no trouble with it. He was even able to induce the start signal to the engine and start it.
Any ideas what could it be? What else can I check?
Thanks in advance for any information you can provide me.
Carlos
Carlos
