Numbers shown are quanties used per assembly. Prices are based on a quantity of one (Each). Order the quanties needed for repair.
ORDER
QTY REF.
NO. PART NO. PROPULSION SYSTEM - EXTERNAL
DESCRIPTION NORTH AMERICA (CU)-ENGINE 1503 HO ETC
31CA PWC's
PRICE EACH
1 205562560 SOCKET HEAD SCREW M6 X 25, SCOTCH GRIP 3 1.58
2 207362060 HEX. SCREW M6 X 20, SCOTCH GRIP 1 1.17
3 207383060 HEX. SCREW M8 X 30, SCOTCH GRIP 4 1.45
4 234061600 FLAT WASHER M6, STAINLESS 3 0.27
5 234081600 FLAT WASHER 8 MM, STAINLESS 4 0.43
6 250100104 ELASTIC FLANGED NUT M20 1 9.99
7 267000030 ANGLED BEARING 1 64.99
11 267000458 IMPELLER BOOT 1 11.99
14 267000372 WEAR RING 1 68.99
16 267000388 IMPELLER SHAFT 1 97.99
18 267000428 IMPELLER COVER 1 14.99
20 267000469 PLUG PLASTIC, BLACK 1 5.99
23 267000567 STAINLESS STEEL IMPELLER ASS'Y 1 329.99
24 267000540 IMPELLER HOUSING 1 319.99
26 XXX IMPELLER INSERT 1
30 267000663 VENTURI, BLACK (NLA - USE PARTS LIST BELOW) (SEE NOTE) 1
30.A 267000787 ...VENTURI, BLACK (MAY NOT BE SHOWN) 1 159.99
30.B 271001885 ...SIPHON TUBE (MAY NOT BE SHOWN) 1 1.99
33 271000785 WATER OUTLET 1 9.99
34 271001133 SIPHON TUBE 2 7.99
35 267000282 PLUG 1 13.99
36 271001393 SPACER 1 8.99
37 271001813 ANODE ZINC 1 12.99
45 293200086 OIL SEAL 1 40.99
46 293200087 NEOPRENE SEAL 1 13.99
47 293200089 OIL SEAL 1 18.99
49 293300013 O-RING 2 5.12
50 293300086 O-RING 2 5.99
51 293300090 O-RING 1 5.99
52 293300114 O-RING 1 12.99
53 293370038 CIRCLIP 1 9.99
NLA - THIS ITEM IS NO LONGER AVAILABLE AS AN ASSEMBLY.
Powered by HLSM
