superboop
- Scarab
- 255 ID
Have 200 HP Scarab 255 so twins. Apparently these are internally intercooled but I can find anything in the service manual of where the intercoolers are located and how to clean them. Right now once the engines are up to temp if I go WOT both engines will rev up to 8k rpm but after about 10 seconds the starboard engine will get a service light and PO127 will come across the screen: High intake air temp. Problem is I can't find how you are suppose to flush this circuit in the manual. Is it just the normal exhaust.
