jds12
- St. Augustine, FL
- SeaRay
- Other
Hi all,
Working on a 1997 sea rayder with the merc 175 xr2 jet drive.
I have no propulsion and I can spin the lower drive shaft by hand. Am I right to assume a drive shaft is broken or a gear stripped? It was running about 50 mph, lost power and engine revved sky high. The engine still runs fine.
Also, will I be able to pull the jet pump assembly while on the trailer? There's only a few inches for it to drop down. Anything else I should look for?
Thanks, appreciate any help.
