Seadek part 8X cut too big
FLJetBoater
I contacted @JetBoatPilot already through email but wondering if this is a one off or if others have experienced this? It clearly says 2010-2014 240. I don’t think there’s a difference between a 240 and 242 cockpit is there?
Yeah, that cut looks much better. Mine must have been cut for something else and mislabeled.
Do you also have the fuel locker pad? Mine seems to be a bit too large.
That was already installed. I did have to play with the alignment and adjust based on the corners vs. centered on the holes. My worry is the corners may start to peel since they did start to roll on the corner. The real challenging one is the clean out port hatch. That one definitely will not fit if you go by centering the latch holes.
Yeah that’s my worry too with the corners...
I have a 242, so I have seats on the clean out tray and just a mat in the middle.
For the 8X piece they are sending a new one. Seems they cut a 2015 piece and labeled it wrong.
For the fuel tank piece I was able to get it to fit with just a slight bend in the corners. Hopefully it doesn’t come loose. Support said it is one of the pieces they haven’t been able to get a good re-template on so we will just go with what they have.
