RightStuff
- Twin Cities, Minnesota
- Moomba
- Other
Yesterday coming home from the lake I was backing the trailer into the driveway and my wife noticed the center and right side of the trailer lights were not working (all light functions). So looking at the manual for my trailer I noticed that all the center/right light wires go down that right side (I think green and brown wire), so that isolated the issue to those wires. But after poking at a few things I wasn't able to figure out where the problem lies and then it got too dark... FYI, the trailer is a 2013 Shoreland'r without LED bulbs.
Here's what I checked/tried so far:
- Checked/reseeded connections @ truck and boat (at the trailer Y there are some connectors), it's a pretty new trailer so I didn't see any corrosion at any plug/connection.
- Hooked up voltmeter to truck plug and saw the voltage jump up/down on those plugs when the flashers were on.
- Checked trailer fuses in truck and those seemed good as well. So between that and the voltage change at the plug I kinda ruled out the truck, maybe there is something else to check here to be sure?
- Hooked up voltmeter to blinker/brake bulb with it removed. Saw a slight voltage jump with flashers on. I was testing the 1157 bulb housing (black on white ground wire, red on the inside/center connections of the bulb housing), not sure exactly what I should be seeing here, but looked like there was power getting that far back...
- Tested right blinker/brake bulb with a 9v battery and it still works/lights up, so that rules out that bulb. But maybe if another burnt out it would short the whole side of lights?
- Pull 3 center light assembly and check connections/voltage in there. Since this is linked to the right side I was thinking this morning maybe the ground is bad there?
- What other ideas do you have that I should to try?
