Shrinkwrap size
Emptytemples
Easton, PA & Ocean City, MD
Looking to buy shrinkwrap for the AR250 since I don't want to put the shipping cover back on this year. I did it for the 19' boat but looking to see if anyone has input on the size needed for the boats with the towers.
Also, when you guys get these boats shrinkwrapped at dealers, do they fold the tower down or keep it upright? This is the first year I will shrinkwrap this boat. Previously, doing the SX190 was easy. My dad has always had deck boats so never needed a wider roll of shrink wrap.
Uline has shrinkwrap for about 300 bucks depending on the size. The heat gun is another investment but will likely split with my dad or make a business purchase. :cool: Does a width of 24' seem too short? Figure 8.5' width plus 6' drops for either side and we are sitting at 20.5' so a 20' width is likely too small with the wrap around the banding. May have to go with at least a 24' wide roll unless the towers stay in the upright position. Any input is appreciated. My shop is open if anyone wants to wrap theirs and live close to Alpha, NJ.
We wrapped ours with tower up, but you can do it either way. Add a zipper door and you can access the boat over the winter, handy for off-season projects.
Tower up for the last 6 years and I think the guy that wraps it uses the 24' width this larger width is requested by me so that it covers a large portion of the hull protecting it from UV fading exposure. The 2005 model had bad fading of the hull so this should protect it better. I have had the zipper doors installed they always seem to leak I just keep a roll of the tape on hand slice it open climb inside then tape up the slice if work is needed.
I thought the zipper door could leak a little. Maybe tape over the zipper could work as well. Appreciate the insight.
