Back home and on a computer!
To add more:
- The 165 is just a blast! It's a lot of fun all around. Keep in mind they sell it with up to 300HP. I couldn't care less about speed personally so I went with the base 150HP. But if you're into speed, talk about power to weight ratio... Even with the 150HP, I reach about 42mph. My wife complains it's too fast. lol Pivots on a dime. Maneuvering it around marinas is amazing and turns heads around all the time. Obviously they look very stylish which is definitely part of the fun.
- My power train has been absolutely bomb proof after 170+ hours. Zero issues. I do my own maintenance which is super easy with basic tools. But if you prefer the dealer to do that, by all means. Just keep it in mind if you prefer to do your own maintenance. My engine purrrrrrs perfectly since the day I got it. Antifreez swap for the closed loop system every 2 years. Oil change every season. Flush with RV antifreeze to winterize. Fresh spark plugs once in a while. That's been it. My wear ring and impeller are still mint.
Overall, I'm very happy with my boat. But with any boat, you get to learn about the bad stuff too, and I won't pretend there isn't any. I'm not a Scarab fanatic, but I do like what they offer in general.
In order of severity in my mind:
1. It can porpoise on straight stretches when cruising around 30mph. That annoys me like you wouldn't believe. Some people report no porpoising. I think it all has to do with the weigh in your boat and speed you've chosen. Generally, more weight up front will stop or at least reduce it. To correct it, change weight distribution, speed or turn. I decided to try trim tabs to reduce this. I'm not 100% into them since they come with significant sacrifices. But be warned, shorter boats regardless of brand can have porpoising issues.
2. The god damn gas gauge. I don't know who designed it, but wow did I have a lot of issues with the float getting stuck inside the tank. Many other 165 owners and other models have reported this. I've been battling this since I purchased it. After years of being told every story under the sun, I now understand the problem and it CAN be fixed. Most don't have this issue so hopefully you don't have it. But if you ever have it, just don't even bother with the dealer. Talk to me. lol 99.9% of dealers don't know what the problem is and replace your entire fuel sender. All you have to do is slightly bend a rod.
3. Little things like no drain holes in cup holders, I replaced mine. Screws for the main hinges on the rear hatch, replaced them with bolts. The latching pin keeps rotating and let's your hatch pop open whenever the fiberglass flexes due to waves, towing, etc. Just put a lock washer and locktite on it and keep an eye on it over time. Takes 1 min to fix if it rotates the wrong way. The bench seat would float open when I was weightless in heavier waves and slam down hard when you hit the water. I put a magnet to hold it down. Drain holes that do drain correctly, but don't catch ALL the water. I drilled tiny holes in strategic spots to catch all the water. Relays that seem to fail a lot for a lot of people which prevents you from starting your engine. I've never had this problem but it's very common. After speaking with an electronics engineer, he believes most are failing either because they are cheap or more likely, temporary short circuits when people are connecting their batteries. Make sure you connect your battery properly, keep the master switch off until everything is connected. And carry spare relays in your boat just like fuses. Again, never had this issue.
That's all I can think about. As you can see, I'm not a Scarab fanboy. No boat is perfect regardless of brand. It just takes time to find all the faults. lol But in the end, I would buy this boat again. Pretty sad the season is over here in Ottawa, Canada.
