Wisewaves
Funny, my manual says to check them at 10 hours to verify proper operation, not replace. Even the oil filter doesn't require a change until 100 hours per the manual. But if you're doing the oil with the kit, the filters are part of the kit so might as well. My dealer changed oil and filters which I asked for at the first service to help remove any debris.The manual says to check the plugs at 10 hours. Is there any benefit to changing plugs while I do the oil change?
Do you know how long of a socket or extension is needed to reach the plugs?I change mine out every year. If you don't change them, keep the spares on the boat in case you need to. it doesn't take long. One tip though is buy yourself a magnetic spark plug socket....cheap on amazon...it'll keep the thing firmly in place when you're lowering them into the holes.
Inspect at 100 hours in my manual. As you say, no need to change them often unless you're in an area sucking up lots of dust, pollen or similar.Interesting as I don't recall changing the air filters. I guess I should check the manual for that interval. Unless you're operating in a smoky area, the marine environment is generally pretty dust free so those things can go a long time.
Ok so normal then - I do something similar, where I hold the ratchet at the head in my palm so I can feel it there's any tension when installing critical parts. I also spin the plugs backwards and feel for the plug to "drop" into the threads to prevent cross-threading...my father taught me that trick when I was a kid for any sensitive screw-in items.Use a regular spark plug socket. A 6” extension will do it. I also use a t-handle rather than a wrench...that way I can tell how tight the plugs are getting.
That seems normal for fuel injected engines, rich at idle to stay cooler and then lean out the curve as the revs climb.Checked mine at 10 hours seemed a little dark as if the engine was running a bit rich.
Hmm...interesting idea to change the filters a couple of times but I think a magnetic drain plug will catch more debris than the filter. Not sure if these engines have drain plugs...?Engine runs very smooth. Left plugs in - will replace later in summer if enough hours or at fall haul-out. My manual does not call for the oil filter to be changed at 10 hours. Who wouldn't do that - the Yamaha oil kit comes with one anyway. I also bought two oil filters......will spin one off in July and top-up the engine and spin one off in August and top off the oil. Haul out for me will be September/October.
I intend to change plugs with the oil and filter yearly though...they're not expensive.
@212s .....the spin the filters off - top-up oil, is an old trick of guys who run their engines up (fast) - or work them hard (slalom ski/tube). After some hard use or between changes I spin the filter off, I used to clean the engine mating surface with a non-shed cloth, put oil on the new filter gasket, fill the new filter with oil, install it, (the engine is already hot as I heated it to operating temperature before I removed the "old" filter) - crank it to distribute the oil, take a dip stick reading, add oil as required, check oil and voila. Do this and your engine will last forever. The old filter removes contaminates the new oil refreshes. Learned this years ago from a renowned engine builder.That seems normal for fuel injected engines, rich at idle to stay cooler and then lean out the curve as the revs climb.
"Ever get to 100"???I agree with most here pulled at 10hrs checked gaps put them right back in no issues will change them if I ever get to 100hrs
