Standard Parts…
aemkay
195 Open ID
Hi All,
have a 2018 195 Open ID with 250. Surfing around it seems there is some parts (Fuses, Relays, ???) owner should have on hand. What do you always have on board?
Thanks!!
The fuse boxes already have spares inside. Or should. Just open each one to verify the spares are inside the lids. If not, or you're missing some, get some extras.
These are the types: https://www.amazon.ca/dp/B01J9GTL0A?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_6
For relays, there are two per engine. They are all identical and there are many brands that work the same. I recommend keeping two spares on hand for this reason.
Here's one that works: https://www.amazon.com/dp/B001KSGJH...HKMlpVKfT6OTrLHQQA_aem_SWl38QWIs6W4dm5JQedKEw
Thanks! Fuse link is Amzn Canada, can u throw me the search words? I am in the US ✌️
Anything else but fuses and relays i should have at hand ot on the water?
Just "mini blade fuses".
Personally I carry:
- 3 spark plugs and the required tools to change them
- jumper pack
- Hose pinchers in case you need to get towed and PRE mark the hose(s) with bright yellow tape so if it ever happens, you know immediately which ones to clamp
The rest would be generic tools, cleaning products, etc. Like any other boat.
Before you ask lol
And plugs are NGK DCPR8E (4339). The 4339 means the ones with the silver REMOVABLE terminals which you need to remove before installing. The other version of these plugs have a darker non removable terminal.
