Sccala
- Westerly, RI
- 242 Limited S E-Series
Hi everyone. So, I have a 2011 242 limited. I bought it four years ago and have had no real issues with it up until now. This past Sunday, I took it out for a few hours, and everything was fine. However, on my way back to the dock. (I do not trailer it, I keep it at a slip) I felt that the right hand turning was not as fully responsive as it should be. It was hard to fully test out, because as we all know, steering at low speeds is not the best way to test something like this out. I need to be at full speed, but I was already in the no wake zone and was done for the day. So, I took it out this morning and opened up the throttle’s. Both throttles were responsive to what I’m asking them to do and tach out properly. However, when turning to the left… Fantastic, tight banking turns. But when I turn to the right with the steering wheel as far to the right as it will go, it does not turn in as tight of a circle as it does when I go to the left. To put it simply… If I did a full circle with a left-hand turn, that circle would be a lot smaller than if I did a full circle with a right hand turn. When I go back to the dock, I opened the hatch behind the steering wheel, and turned the steering wheel in both directions several times while inspecting the steering cables. Nothing seem to be abnormal. everything was tight and in place. This issue happened at some point mid day on Sunday when I had the boat out for a couple hours. Because the entire time I was out, everything was fine up until I was in the final no wake zone on return and noticed that it wasn’t responding very well. Not sure what could’ve happened out of the blue, but wondering if anybody has any thoughts. Thanks in advance.
Steve
Steve
