Boat Stuff Stuff for a single engine 190 boats.. 190FSH, 190SX, AR190, may fit 192's and 195'
kthrash
Madison, MS
So, back when I had my 190FSH, I bought some stuff to do the Ribbon delete on it.. and a pump wedge to get better hole shot..
I have the following for sale:
Spectre Performance 9132 Universal Clamp-On Air Filter: Round Tapered; 3 in (76 mm) Flange ID; 6.5 in (165 mm) Height; 6 in (152 mm) Base; 4.75 in (121 mm) Top (Paid $15.99)
Spectre Performance 8704 Worm Gear Clamp - Pair (Paid $5.28)
Yamaha Waverunner 1812cc HO SHO SVHO Billet Intake Mesh Delete Ring ( Paid $35)
Yamaha Waverunner 1.8L SHO SVHO FZR FX FZS Billet 2 Degree Pump Wedge (Paid $85)
Also stuff for push button start/stop on a single engine:
Ulincos Momentary Push Button Switch U16F1 1NO1NC Black Metal Shell with Red LED Ring Suitable for 16mm 5/8" Mounting Hole (Red) (Paid $8.38)
Ulincos Momentary Push Button Switch U16F1 1NO1NC Black Metal Shell with Green LED Ring Suitable for 16mm 5/8" Mounting Hole (Green) (Paid $8.38)
Ulincos NOT FIT U16C2, 16mm Pigtail, Wire Connector Only for U16F1, U16F2, U16F5 Push Button Switch (Pack of 2) (Paid $6.48)
Open to offers on all or some of it..
Pump wedge? Didn't know that was a thing, interesting...
So that ring is all you need to do the ribbon delete on the 1.8L? It looks like it fits 190/192/195 the same. If so, id be interested. Also, what were you planning on doing with the new switches? Just swapping out for color?
I was going to install push button start/stop so you didnt have to use the key. you need the airfilter too with the ribbon delete for spark arrest..
