Switch for 165 Ho 2017
PeterJB
165 ID
I have a scarab 165 HO where all the swiches on the left panel is broken. Do anyone know the part number on those ?
it is Carling Technology and is for the bilge , blower and Nav/anc lts .
Peter
scarabjetboats.com then scroll to the very bottom, click on the Parts Catalog link. Pick your model year from the pull down menu, then your specific model. First link Z01 Standard Parts List is next.
Then you drill down in the expansion menus. SBHOI 165 SCARAB HO IMPULSE JET 2017 followed by P/L, SAHOI BOW/COCKPIT HDW. Then HELM ASSY, SA, and finally PANEL ASSY, SWITCH, SA.
There are pics you can use to verify the part you need.
Note that these are Scarab part numbers since they are manufactured or purchased by Scarab itself. In order to get them, you're suppose to contact a Scarab dealer so they can get it for you. There is no other way to get such parts elsewhere. If the switch is made by another manufacturer, and not Scarab itself, then you can google search yourself to see if it can be purchased somewhere. But there is no official way to do this. You're essentially on your own to do that IF it's even possible.
Finally, I have to ask because you're aren't clear. what do you mean by "broken" exactly? We get a lot of people reporting lots of problems. Are you saying they are physically broken? Or not getting power (which is way more common). Because no power doesn't mean they're broken. In that case, it's way more likely to be a fuse or a connection issue.
Thank you very much. Wih broken i mean that it is not working. I had an electrician measure it. The boat shop nearby had some switches that fit, ao have installed new ones event though they look different. But it works perfectly.
Tks.
