cjaysanchez
- Porter, TX
I was picking up our 2021 195s and during the test drive before I took her home, the alarm for depth kept going off, then showing 12 ft and instantly will go to 3.5 feet alarm, then a high pitch noise almost coming from the speakers as a faulty ground, even with the engine off and switch to off (not floating) you could hear a noise, Bluetooth error showing on screen. My point is that perhaps we could have sucked weeds explaining a high pitch sound coming from engine and I am thinking were the speakers, the depth alarm being triggered by weeds under water. Still noise after turning ignition key to off is Something definitely wrong with the wiring. It comes with wet sounds oem and don’t believe it includes an amp since that could be a grounding issue I saw in other posts. If you could share the symptoms when sucking in weeds. The engine was always running and keep in mind that our speed was no-wake and then under 5,000 rpms. It was a Saturday so not enough time to figure it out the dealer said. The dealer Has her and hopefully they will figure it out.
