robert843
- Myrtle Beach, SC
Well after driving @1948Isaac boat a little while fishing last week my throttles are way tighter then his and harder to push forward or back his where very fluid easy and smooth. When I pop the plastic piece to access the tension er screw are there multiple screws in there if so which is it and which way do i turn it to loosen the tension? My boat has the slight throttle drop issue and I'm assuming the previous owner tried to fix it by tightening the tension er screw to much not realizing that isn't the problem.
