. I usually just hand tighten the bolts and add another 1/4 turn with a ratchet wrench
Wow my 2018 manual doesn’t seem to have that level of detail, just general torque for smaller/unspecified bolts.Here is what my service manual for a 2010 242 ls with 1,812 cc engine says. This is the first time I’ve seen this. I usually just hand tighten the bolts and add another 1/4 turn with a ratchet wrench. The coils mounting holes are lined with a metal sleeve so you should worry about damaging them by over torquing, just don’t get crazy when you reinstall the coils.
Your wrench is too big (she said). Scratch that, I have two with different ranges. Sounds like you only have one with a higher range.Wow that ain’t much. 120in /lb is min on my wrench!
You should. Once you have it, find a local company that does calibrations and see what they charge. For a shade-tree mechanic like ourselves, a single calibration is worthwhile. I've seen quality wrenches come off the shelf as much as 15% off target. Don't pay over $50 or so for a calibration though.This is how I have been doing it. I always question if I had it tight enough. Wondering if I should pick up a torque wrench?
Totally agree on importance of torque wrenches, especially on bolts going into aluminum.You should. Once you have it, find a local company that does calibrations and see what they charge. For a shade-tree mechanic like ourselves, a single calibration is worthwhile. I've seen quality wrenches come off the shelf as much as 15% off target. Don't pay over $50 or so for a calibration though.
You're most likely over torqueing everything you touch if using the "add a 1/4 turn" method. 5.9ft-lb is VERY VERY VERY low torque. You can apply this with a screw driver and a strong grip. 1/4 turn additional is most likely closer to 50-60ft-lbs depending on the joint.
Snug (in general) is defined as when the bolt stops rotating freely and all surfaces have come in contact with one another. Additional turning of the bolt (or nut) only adds clamp load and does not change the geometry of the joint. This additional clamp load comes from stretching of the bolt material along it's axis. You should always snug the joint, THEN apply proper torque.
The loading on those coils is very low. It's a positional load only, not a seal, clamp, or shear load. 1/4 turn past snug is significantly excessive.
Source: I design bolted connections for vibratory equipment. Here's my latest bolt stretch test with a custom designed fastener to achieve proper clamp load. Achieved a shade over 120,000lb clamp load on the 1-3/4in bolt with only 75 ft-lb of torque on the 3/8in jack bolts
View attachment 144425 View attachment 144426 View attachment 144427
