DrCalculator
- AR195
Hello All! I'm about to be a new member with an AR195 2020. I have to drive about 4 hours to get it, so I'm trying to make sure I'm set with the trailer hitch ball height. Does anyone here have any idea about what drop I should use with the Ridgeline hitch? Unloaded the bottom of the receiver tube is about 17.25", top is 19.25" (2" receiver tube). If I use a 2" drop hitch I suppose the top of the ball will be around 19.75". If I use a 3 1/4" drop I think it will be around 18.5" to the top of the ball. Then subtract maybe 1 1/2" for compression from tongue weight...
So, can anyone help me with some pointers, advice or knowledge about the best setup. Thank you very much!!!
