4x15mph
- Downingtown, PA
When retrieving the boat, I was finding that the boat would touch the front "arm" of the trailer at the Y when winching it in. I was able to overcome this by not putting the trailer in as deep. Today the boat didn't go on as straight as usual and after inspection of the bunk boards and the mounts that hold them up, it looks like one of them definitely moved since it is at a different spacing than the other one.
I think I might be able to jack up the mount which will push up the bunk board but what is the proper way to align and angle/pitch for the bunkboard? Should it be parallel to the ground from front to back and can I just use a level to dial it in? I will start to google but I thought others may have been through these adjustments in the past.
Thank you
Thank you
