Jason Talley
- Pearland, Texas
I ordered a Trailer Valet 5x and it just arrived. After some time with it, it seems as if I'm having a hard time figuring out how I'm going to mount it on the trailer. There is only a small gap between the factory stand and the trailer split to the rear and only a small gap from the factory stand and the folding joint. Neither are wide enough to mount the Valet. It is possible to mount on the extension arm of the trailer that folds in and out, but it would require longer bolts as it is slightly wider than the main trailer frame.
I don't want to adjust the position of the roller/factory stand as it seems like it is set for the boat specifics but I cannot determine any other location to mount it....
