itsdgm
- Rancho Santa Margarita, California
Since I'm usually towing several hundred miles to use our boat, I've always been of the school that likes to trailer with the boat covered. I trailer with it covered for several reasons. The main reasons are simple. Since I tend to load the boat up with a lot of crap, I don't want to get to the lake and be missing things. Things tend to leave the boat for several reasons. Sometimes they get sucked out on the highway, and sometimes they get lifted out while taking a break for lunch. Which IMHO sucks worse. So "out of sight, out of mind".
Feel free to post your pick and tips too. I'm sure there's more than one way to get the job done. This is how I do it.
I start by putting some pool noodles over the windshield. I found that without them, the cover leaves a sticky mess on the windshield frame. I believe this residue is from the cover buffeting itself to death on the edge of the window frame. So this step should help extend the life of the cover.
![IMG_6191.JPG](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/2/2597-51c848ca6a5454b3a853543c5c760946.jpg)
Next, I remove or at least lower the anti-pooling poles. I'll leave the straps in place if rain is forecasted, but the poles need to be lowered or removed to prevent stress on the cover while under way.
Then, I'll simply install the cover. The cover is cinched down by the two ratcheting straps located at the rear of the boat. I make sure that it's tightened pretty well and so far I haven't had it come loose at all.
![DSC07243.JPG](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/2/2598-a611eaf0de177d50429c2ac5351dbf22.jpg)
![DSC07244.JPG](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/2/2599-09f17d603a4467acc648c5a34a1e7147.jpg)
Since our AR210 has a tower, the cover has buckles that are used to go around the frame of the tower. I have found that these buckles tend to twist in the wind and can scratch the hull of the boat if left on its own. I use seat belt shoulder straps, found at Walmart for about $6 each, as padding in those areas.
![Cover Strap 3.JPG](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/2/2601-6aef17cc77d2b180b4a446f74bbcac73.jpg)
![Cover Strap 2.JPG](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/2/2600-7e953c0cf5b717c2612cc949aa172147.jpg)
